RCU Forums - View Single Post - Special Effects?
Old 03-11-2005 | 01:38 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Special Effects?
ORIGINAL: thegreatwarrior
Thats kool, But how do you do it?!?
Ok, to give you an idea, Here's a picture I found, the first is befor and the last is after. The second pic is the steps in between
1Start by cutting out the car, and pasting it as a separate layer
2 you can't just blur the background or the fuzzy white edges will show through
3 So you have to fill in the edges with some surrounding picture - I filled in the entire area, but you don't have to, just the edges will do.
4 Now you can add a motion blur filter
5 Next, I pasted on a layer of the car, blurred it, and erased the front half.
6 then I pasted the original image.
In the final pic, you can see that I added a radial blur to the wheels, and just a slight motion blur to the car.
Voila!
ID:	242203   Click image for larger version
ID:	242204   Click image for larger version
