RE: 1/5 Pepsi Chipmunk - Build
Ari,
It flew beautifully!! Straight as an arrow, all that it needed was a bit of "up" trim. The Saito 180 is nearly too much power. Less than 1/2 is good for cruising and full power gives vertical-not exactly scale!
I'm very pleased with the results of this kit. Have you flown yours? Go with the recommended control throws, and program some dual rates and exponential. the roll rate on the trainer is very high, and the super has larger ailerons!
Take care,
Randy
