RCU Forums - View Single Post - ??? How to Paint Camo Scheme on Monocoat ???
Old 03-11-2005 | 06:11 PM
Dai Phan's Avatar
Dai Phan
Default RE: ??? How to Paint Camo Scheme on Monocoat ???
Hello,
Use my PROVEN method:
1. Iron out all bubbles on monokote.
2. Use 00 grade steel wool as 000 is way to fine. DO NOT use sandpaper as it is very easy to go through the clear coating.
3. Clean out with alcohol, not acetone as it leaves some sticky waxy residue.
4. Use Createx Auto Air to paint by brushing or spraying. This paint goes on smoothly and dries LIGHTNING fast via heat application ( heat gun or hair dryer).
5. Clear coat with LusterKote FLAT or GLOSS pending on the type of plane.
6. Any wrinkles can be fixed via HEAT GUN (not Iron as it will mar the finish).
I have NO problems of having paint peel off. Use this system will make a believer out of you! Dai ( see my O-1 Bird Dog thread where I use this system).
