RCU Forums - View Single Post - Futaba 6EXA servo problem
Old 03-12-2005 | 11:52 AM
  #33
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: Futaba 6EXA servo problem
Two y extensions are being discussed. I think the consensus is the easiest solution is to use a y SERVO extension. This is simply a wire that allows you to plug two servos into one receiver channel, in this case channel 2. This way both servos are controlled by one channel. Here is an example. http://www2.towerhobbies.com/cgi-bin...&I=LXL307&P=ML
