Battery Pack Weight
I use to use sub-C packs and have switched back to AA. The weight was not worth it and in the Fury it made it to nose heavy.
"Is the CG determined from the main rotor shaft? Or does this vary from model to model."
All helis balance at the same point that's it's fulcrum, at the main shaft.
Every ounce matters just my 2 cents.
