RE: Starting gas and set up
If you are using straight propane, that may be part of the problem. A propane/butane mix is much preferred. I busted my gas valve, so couldn't use starting gas for my 54, I found that the presurized butane cylinders (the little ones for refilling lighters) worked beautifully in a pinch...
