RE: Fidgit contest plane pics
Thanks CP. Yes, the upper wing will be supported by struts at the wing tip. If you look close at the first pic, you will see the copper tube that the steel rod will slide into to allow the wings to pivot.
I made the nose a little short because I was thinking that with all the weight of two wings and engine, and with no horizonal stab, it would be just about right?
