RE: Keeping muffler bolts tight
Set your bolts up in a drill press, or hand drill if nescessary, Drill a hole through each bolt head. after tightening bolts just run wire from one bolt to the other. I use stainless steel wire. I have never had a bolt come loose. It's impossible unless the wire breaks.
