RE: beginning ARF
The JR radio will give you more range than a park flyer radio but for small models I don't see much advantage of buying a 6 channel radio. The servos that come with the radio are probably too big for most park flyers airplanes. Need more info! Do you want to stick with electric power or do you want to move up to glow power planmes? Most glow powered planes are made of light plywood and balsa. This is stronger than foam and easier to repair if needed. Hope this helps. [8D]
