Help triming an all white plane
After a lot of thought I have decided to keep the all white
Edge 540T. Now I need a little advise from anyone who
has added large pieces of trim over Ultracote.
After searching and reading a ton of posts it looks like i
have 3 choices for adding the trim scheme over the white
ultracote....
Option 1 - apply Monokote over the Ultracote with the windex
method and then go around the edges with trim solvent.
Seams like it would work, and I can get paint to match the
Monokote for the cowl etc.
Option 2 - apply Ultracote over the white ultracote with the
windex method and use low heat to seal the edges.
Again this seems like it would work, but I have no experience
with Ultracote, but from what I have read some like it better
then Monokote? And I read that matching paint is hard to come
by for Ultracote?
Option 3 - apply ultracote over the white ultracote with low
heat only.
Same as above.
Did I leave anything out? Tom, have you had any reports from
client's as to what method works best?
Thanks for your help.
