RE: Help triming an all white plane
The way I would try it would be to first make a cardboard pattern of the yellow and blue for the wings stab rudder etc..Then lay the pattern on the wing and trace it..then leaving a 1/4 gap cut out the pattern on the plane..then trace your pattern on the covering and apply it to the stripped areas..the checkerboard can be bought pre made or you can just cut out the sqaures..make patterns for the stab fin etc..the hardest thing will be matching the paint for the cowl.
