RE: Close Call, and the lesson learned
For newer pilots, check your Dual Rate for low rates if that's what you really want to start out at (first flight of the day for instance). I did not and, with a combination of strong gusty winds above the tree line, I ended up with a pile of scrap balsa and a quick ride home. My mistake started with not assigning the same percentage for both low and high rates (basically disabling the dual rate function) until I was ready for high/low rate functions. I was not ready for high rates but it was in high rates. The flight did not last long, mainly because I was confusing the strong gusty winds (partial contributor) with my over-correcting movements on the control sticks. Pilot error.. no excuse sir! Rebuild and remember.
