RE: Funtana 40 3D prop problems
currently my plane wieghs about 5.5lbs, so i don't think that the weight is the problem. i have finally got the motor running perfectly to the way i want it, and i have no cash availalble that i would be able to buy the fa-82 and install it.....i think i will try the change of prop, getting more rpms out of it may help, especially since i already have a 13X8 laying in the basement that i originally had installed, but wanted to slow it down a little....
one other quick question while we are on the subject of this plane, what shouldf i do to seal in between the ailerons and the main wing?? i was starting to get a little worried last year when i started doing some fast flying about getting some flutter and then putting it into the ground.....
Andrew
