RCU Forums - View Single Post - Tail Slide...
Old 03-15-2005 | 10:48 AM
ampa
Default RE: Tail Slide...
from straight level pull up to vertical,once your bird is perfecly vertical cut the engine the model will stop and(is mandatory) will begin to come back tail ahead still prfectly vertical now you have two choises: if you give elevator up the model will drop the nose with the landing gear dow(tail slide gear down) if you give elevator down the plane will drop the nose with the gear up(tail slide gear up), to be successfull in these maneuvre is important when you cut the engine that the model is perfectly vertical otherwise it will not come back tail ahead.
