RCU Forums - View Single Post - Looking for ESC without BEC
Old 03-15-2005 | 12:57 PM
-pkh-'s Avatar
-pkh-
Default RE: Looking for ESC without BEC
Just clip the red (power) wire from the ESC to the RX to disable the BEC from powering the RX (you now need an RX batt pack), and install a switch between your 9V batt and the ESC, if your ESC doesn't have a power switch on it already. If you want only one switch, you can get a dual throw switch that will turn power on/off to both the RX and the ESC... a SPDT switch will allow you to turn power to both on/off, and a DPDT switch will allow you to switch the batt s from the RX/ESC in the "on" position", and then to charger leads in the "off" position (like regular RX pack wiring harnesses do).
