RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 03-15-2005 | 04:00 PM
  #1424
Britton
Default RE: U-Can-Do 3d 46?
My U Can Do 46 is no more. The first problem I had is the same as yours the gear came off a couple of times do to weak glue. So i got the bright idea of making a brace out of thin steel. I cut it as a T brace and ran the laning gear bolts threw it and attached it to the gap under the fire wall. This looked good but the next flight I had an engine failor 15 feet over the grass too far away from the field ( I was setting up for a hover). I touched down as soft as possable. Well the landing gear held Wow did not break. But from the left side in back of the canape broke off to the begening of the canope on the right side. The airplane could be rebuilt but I would have to start from the rear canape foward complete build not rebuild the cracks and breaks were very ruff. The wing needs alot of work too. I learned it is alot beter to loose the gear then the entire front half of your plane. Just keep some CA on hand for a fast repair. now I am flying a Funtana 40 and like it alot. I want to get another U-Can-Do some day but out of hobbie funds for a while.
