More on the raptor setup.
..Ok I try to setup my raptor30. And I got som questios for you..
First:
I cant get the pitch right. Im seting up the heli for 3d flying, so i whant +-9.
First I hade to move the pitch ball link to the outer hole on the servo. But now I have a strange probleme. One side is almost perfect when I measure with the pitch gauge. But I cant get the other side to line up. If I adjust both of the blades to be -9 at the bottom they dont line up at the top, one blade is +9 the other is +8 degrees.
And when I adjust both of the blades to be +9 they dont line up in the middel. One is 0 degree and the other is -2. Im getting frustrated!
And the clutchs is grabing the bellhousing. Is this something that will wear down during normal operation?
I hope you can guid me right....
Regards
