RCU Forums - View Single Post - More on the raptor setup.
Old 09-21-2002 | 04:33 AM
flmgrip
Default More on the raptor setup.
before you setup up your heli for flying 3D you should learn the basics of flying with a less radical setup...
regardless... don't worry to much about the two blades being the same, the pitch gage will give you a rough number anyway... if you use would blades, they might be warped....
do the final setup in flight, tracking of the blades first and than max climb-out rate without bogging the engine upside right and inverted... that will determine your max pitch... not the gage...
wouldn't worry to much about the bell if it is a new heli it will wear in...
hope that helps
