ORIGINAL: tailskid
I used a Saito 91 in mine and it had more than enough power - don't know of any gas burners that small. You will find the kit builds very fast - only changes would be to mount the servos in the wing the correct way - not the way they recommend. Also replace the bottom stringers with pine or basswood as the balsa cracks too easily when you pick the model up!
Jerry
Just curious what is the difference between the "corrrect way" and "the way they recommend" in mounting the wing servos???
I have one of these sitting in a box waiting to build...too many other projects going right now...
