RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 03-15-2005 | 07:57 PM
  #1427
gjeffers's Avatar
gjeffers
Default RE: U-Can-Do 3d 46?
ORIGINAL: hockeyrules99
Quick question for anyone running a Saito 82 on the ship inverted..I've seen lots of post recommending Kline etc...however I've seen a few that had nothing more than stock..how are you keeping the the fuel from siphoning when the engine is inverted..without using pressure regs? Engine will be here on friday!
hey John, without a cline or other reg you can use a great planes easy fueler valve and just keep the fuel hose hooked up till you are ready to start the engine then unhook and start it. but the only way that seems right is the regulator or you will be fighting fuel all the time. if money is no prob then the cline is the way to go.
