RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 03-15-2005 | 10:37 PM
  #1429
gjeffers's Avatar
gjeffers
Default RE: U-Can-Do 3d 46?
John that is correct, as long as the fuel line filler is pluged in to the easy fueler valve the fuel line to the carb is shut off so you can not flood the carb. but as soon as you are ready to start the engine and flip the prop or use your electric starter, remove the fuel valve and start right away! i had that setup before i got my cline and it worked out ok as long as your engine is an easy starter and you do it prompt. and also remember you do not have to prime your engine! your fuel will naturally prime itself.also if your engine does not start pretty quick then plug your fuel conection back in to stop the fuel to the carb and clear any excess fuel from the engine and start over.
Good luck
