RE: Funtana 40 3D prop problems
Yes, Funtana 40 will yaw if you give enough thrust and rudder. But it requires too much of both to hold a hover. A good 3D plane should require only moderate amount of rudder and throttling to correct yaw from a slight fall-off.
