RCU Forums - View Single Post - servo problem
Old 03-16-2005 | 02:43 AM
yan7
Default RE: servo problem
ORIGINAL: FLYBOY
What kind of system? It could be your antenna. How is it mounted? Could be a bad Rx Crystal too. Depends on what system it is though. Give us more info.
iy's a hitec eclipse 7 with 4 hitec servo n a futaba digital servo for the rudder!the antenna seems to be okay!do u think it's the crystal?coz i had no similar problems before,i just started to hav them when i finished taping the receiver,attaching the wires n putting the rubber foam!i had attached my battery indicator on the foam which was right on the crystal but then i removed the indicator n the foam n i got the prob once more!am still puzzled for that!i also saw that i had plugged the battery wire upside down by mistake!(the yellow wire being down) do u think it was this which caused all this?
