RCU Forums - View Single Post - FIXED!!!! 14MZ Throttle Cut problem
Old 03-16-2005 | 09:13 AM
tekati's Avatar
tekati
Default RE: FIXED!!!! 14MZ Throttle Cut problem
Yes positive. Once I found that you can actually press the CENTER DIAL as a momentary switch I started using that for Throttle Cut only. I have another switch that I use for idle down and it was definitely off.
