RCU Forums - View Single Post - Engine Cowling
Old 03-16-2005 | 09:32 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Engine Cowling
ORIGINAL: Airdale CPO
If I cannot find the weld-on then I will use the thin CA.
Either use medium CA, or be VERY careful! Thin will run all over the place (I would suggest taping the outside of the joint with masking tape to prevent it running out and onto the outside of the cowl)
Using the fiberglass on the inside of joint I will still need to use CA or the Weld-on correct?
Here it is best to use CA. Weld-on is for plastic-to-plastic joints
