RCU Forums - View Single Post - Futaba 9C programing?
Old 03-16-2005 | 09:42 AM
tcblr
Default RE: Futaba 9C programing?
ORIGINAL: DP01
The simplest method is as follows:
1. Basic Menu - Aux Channel change to SW C. This provides 3 position +100% /0%/ -100%
2. Basic Menu – End Point With SW C in Up position adjust desired (say 75%), with SW C in Down position adjust as desired (Say 90%). This provides Flap Up with SW C Up, Takeoff Flap with SW C Centered and Landing Flap with SW C Down.
Play with the end points until you achieve the values you need. No P-Mixes required. (You can use the Basic Menu - Servo to immediately see the effects of your adjustments with the module removed during programming).
Dennis
Edit: If needed, you can also activate AIRBRAKE to provide delayed elevator trim at full flap.
Dennis,
Thats how I currently have mine set up but as Todd mentioned unless we are missing something you can't adjust the center position's end point and thats the problem that I'm trying to address.
If there is a way to adjust the endpoint in the center position then no doubt this would be the easiest method.
