RE: retracts for Skyshark Avenger
OK, The bass part goes to the pump. the filler is connected to the "T" one side goes to the tank the other to the slide valve the two reteacts connect to that valve. Its really a easy set up. If you want to play with it just hook it all up and mess with it. Once you have done it once you'll pick it up quick. Mike
