RCU Forums - View Single Post - UCANDO ELEVATOR QUESTION>>>>>>
Old 03-16-2005 | 04:30 PM
kneewhack
Default RE: UCANDO ELEVATOR QUESTION>>>>>>
ok guys- I bought the y- harness with reverser. It moves the ele halves in the proper direction, but the travel is not the same amount on both sides. I've been unable to correct this with the adjustment on the reverser or by adjusting the clevis's. This is exactlygetting frustrating. I have a 6 chanel transmitter so I have no place to plug in an extra ele servo. I'm thinking that the reverser will only work if the pushrods are the same length. I notice that on the 60 size the ele servos are located exactly across from each other , but on the 46 size they are offset slightly causing the pushrods to be of slightly different lengths. Any suggestions?
