RCU Forums - View Single Post - Engine Problem
Old 03-17-2005 | 01:21 AM
killer89's Avatar
killer89
My Feedback: (-1)
Default RE: Engine Problem
Do these steps in order:
1. Reset needles on carb to four turns out from closed on the high-speed needle and flush with the inner barrel on the low-speed needle (when turning the needles, make sure not to turn it in too far and too hard because you will damage the o-rings) set the idle art opening to about one to 2 mm
2. make sure your glow ignitor is charged
3. make sure your glow plug glows
4. check to see that your head is on tight
5. try starting the engine
6. if it doesn't start, remove the air filter and try again
After you've done all of this, tell us what happens and I will try to help you more if needed.
