The question is, if you turn on your radio while someone else has the pin, are you responsible for their plane. Not are you responsible if the plane doesn't cost over $400 or are you only responsible if you do it on purpose
Of course you are responsible I never argued this point from the beginning of the post.
Once again, if i see a jet flying i know that he's only going to fly for maybe 7 minutes. Instead of taking a chance, I'll just wait a couple of minutes until he's landed then I'll go ahead and fly. That's using a little common sense. If there's a Ferrari cruising down the road in front of me,
If every body thinks the way you do then there wouldn't be a reason for this post. But knowing every body doesn't think like you this where the 10k jet flyers responsibility should kick in .....
If there's a Ferrari cruising down the road in front of me, I'm not going to tailgate it, I'm going to give it plenty of extra room because I know there's no way in **** that I can afford to ever replace it!!
I wouldn't tailgate a junker never mind a Farrari. Besides I work in NYC often and I almost never see a Farrari cruising any where. Would you like to guess why ?
