RE: What is minimum distance between mailwheel on a jet?
Why not put the retracts in the wings? I have one like that, and it is quite easy. Cut out the foam, insert a couple hardwood blocks, and put the gear in. The Reaper is very stable on the ground so you could probably put two mains in the fus, but the wings work fine.
