RCU Forums - View Single Post - Arm for Hitec 5945?
Old 03-17-2005 | 10:29 AM
rctom's Avatar
rctom
Default RE: Arm for Hitec 5945?
It depends on the length your horn is set to. Use arm length/horn length=ratio of deflection. If you use a 1.25" arm and a 1.5" horn length then surface deflection degrees = 1.5/1.25* servo rotation.
In this case if the servo rotates full 60 degrees then surface deflects 1.5/1.25*60=50 degrees of deflection.
A longer arm puts more stress on the servo and gears.
TF
