Hi,
the geometry file for AFP was an .OBJ file.
The geometry file for AFPD is a .TGO file.
This means:
1. We can only zoom models from AFP, not AFPD.
2. You have to remove a .TGO file from the aircraft folder, because it will load first.
You should modify the TMD before loading the aircraft in AFPD.
If you rescaled the model to 50%, rescale all the joint coordinates by the same value.
Example:
cd JointFuselageLeftStabilizer/
R = tmvector4r( -0.8580, 0.0000, 0.0528, 1 )
Scale the first 3 values, they mean the x,y,z distance from center.
BRG
Rodeo
www.rodeo.onlinehome.de
