RCU Forums - View Single Post - Another covering question
Old 03-17-2005 | 07:24 PM
CGRetired's Avatar
CGRetired
Default RE: Another covering question
Just make sure you sand the surface very smooth using a very fine grit sandpaper then vacuum it two or three times to remove the dust. Then go right ahead and apply the film coating. Make sure you follow the instructions regarding heat.
