RE: Another covering question
One of the biggest causes of bubbling and bad covering is incorrect iron temperature. Too hot is usually the case. I use an IR temperature gun. Using a good quality iron (one with a really good thermostat) helps a lot. Check the covering manufacturers recommended temps and start with those. Experiment using off-cuts on scraps of wood to test before starting a big job.
Safe Flying!
