RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 03-17-2005 | 10:00 PM
  #1448
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Well, I guess I was lucky when my landing gear block broke out. The scoop shaped piece in front of there broke out as well, right along the side seams. I was able to glue in the landing gear block in and then add some gorilla glue around the entire inside base of the block and let it sit untill the glue cured. The gorilla glue expanded into the seam and against the fuse body. The gorilla glue expanded against the sides and created a nice fillet. For the block to come out it would have to take the fuse sides with it. You might want to try that. Just cut out the scoop (ramp) forward of the landing gear block. Once it's out you'll have better access to the L G block.
