LRP F1 Pro Reverse
LRP F1 Pro Reverse: ok just a quick question again, i own this esc, and i was wondering what is going on.. i checked on the site, and it said on the specs that the motorlimit is 13x and lower depending on the wiring.. BUT on the box it says right on the front NO MOTOR LIMIT. the guy at my "lhs" said it had no limit either..
i was wondering what it the max amount of cells i can run on it, also running more cells, that will make the motor heat up more correct? and ill need deans, or someting?
