RCU Forums - View Single Post - Is this epoxy ok?
Old 03-18-2005 | 06:15 AM
paul_c
Default RE: Is this epoxy ok?
ORIGINAL: whstlngdeath
You'd be better off just getting some fresh epoxy for building, as I don't think the finishing resin is made to hold stressed areas together. It's basically formulated to apply fiberglass cloth to wood or plastic, to flow evenly and to be easy to sand. These properties in my opinion make for a epoxy that's not necessarily strong enough to build with. You're going to need some regular epoxy sooner or later for a balsa model, so you might as well get some now.
Jesse
OK, thanks Jesse. Originally, I had used the Z-Poxy to fuel-proof a fuel tank area.
