RE: Inverted Engine Probs
I've noticed this happens sometimes with this engine if the bottom end is set just a LITTLE too lean [ie the screw is too far in]. Might be worth checking for this easily remedied problem first, just in case? If it turns out not to be the problem, then follow the good advice, above.
Good luck!
