ABC Engines and NItro Change
You can always go up in nitro, but the piston and cylinder will go through a miniature "break-in" with the higher nitro fuel due to the higher temperatures. Not a problem unless you try to go back to 10% nitro later, most abc/abn engines won't run well anymore when you try to go back down in nitro.
What I know, JJ
