RCU Forums - View Single Post - I Need HELP!!!
Old 03-19-2005 | 11:56 AM
reneb
Default I Need HELP!!!
I have a SUPERSTAR EP, WITH A MAGNETIC MAYHEM motor and GREAT PLANES GD600 gaerbox. I fried the original speed control. Replaced it with a GREAT PLANES 30AMP MINI. The first flight was fine, after the second flight the motor seems to have a sputter, on full throtle it's fine anything less it starts cutting on and off. The motor doen't stop it just sounds like it has an intermitent connection. While i hold the plane and give it gas you can see the alerion servos start to move(shake,twitch) All of the solder joints are fine. Now, if i disconect the aleron servos it fine, no cutting out of the motor. From a sugestion, i wraped the speed controler with aluminum foil. Again the first flight was fine,then after that it started doing the same thing.
CAN ANYONE HELP ME!! I THINK IT'S NOISE BUT NOT SHURE WHAT TO DO. I CANT MOVE THE SPEED C ANY FARTHER AWAY FROM THE RECIEVER. OH! I FORGOT TO SAY IT NEVER DID IT WITH THE ORIGINAL SPEED C.
