RE: I need help NOW...Im fed up with this
Block the carb with your finger...........(no air filter) then remove the pressure pipe and block that then blow into the exhaust tip ( muffler) pipe.......nothing should come out from the joint/header joint.
I hope this is ok............i never had to explain how to do it,
