ORIGINAL:
[email protected]
And i have a problem, to begin with, in the diff rebuild kits, the differential nut holder used to be made out of black nylon, but now, in the diff rebuild kits, they are made out of chromed metal. So, since i had to rebuild my diff, i did. But when i finished, i couldn't get the CV shafts to fit properly (talking about the CV shaft that gets in contact with the nut holder) so, do you guys have the same problem, or is it just me, and should i take my diff gear apart and rebuild it?
Thanks in advance
You need to insert the screw in the opposite end. The manual is backwards! That is why the nut holder is now made out of aluminum, because people would overtighten the screw - thinking they had to to make the CV shaft fit - damaging the plastic nut holder.
