RE: I need help NOW...Im fed up with this
that migfht work, erm, u want fuel in engine then start, if you try and prime it when theres fuel in the engine then u might flood it.
just put 2 drops in the carb and that shoudl do it. there could be a bloackage in teh carb or something, once it is running @ high revs then this will be cleared (maybe just a very small bit of mud or something) but the pressure should remove it, see if the truck will start first using the fuel in to teh carb, worry about keeping it goin later
