RE: I need help NOW...Im fed up with this
if i put a couple of drops into the carb, it WILL run. but, it will burn that fuel and only that fuel. it will NOT continue to take in fuel through the fuel line from the gas tank. THIS is my problem. any other ideas?
i need to know what to look for. leaks? carb settings? anything that might help.
i did cut about 3 milimeters off the pressure line that was attached to the muffler. did this do anything? i cant try and start it now because my mom is sick and is taking a nap. it will wake her up for sure.
