RE: MVVS 35 with tuned pipe.
Boogie,
I cannot really help you with an exact diagram.
This fitting is usually done with all the parts in hand.
It is best for you to build the plane and after the engine is received, to cut the needed passages for the pipe and the header. Also, to add the mounting hardware for everything.
