RCU Forums - View Single Post - Lube / Shock / Oil Weights
Old 03-20-2005 | 10:36 PM
cssdev
Default RE: Lube / Shock / Oil Weights
You'll want as much traction as possible if you're running a plastic tire solution since they have next to none as it is. You may even consider running with no oil, except a few drops to keep your o-rings lubed. For a starting point set all of your camber, toe, ride heights to 0 / 0 / neutral and run a 10 or 20 weight oil.
