RCU Forums - View Single Post - Started the building phase and have ?
Old 03-21-2005 | 12:14 AM
rctom's Avatar
rctom
Default RE: Started the building phase and have ?
Well put.
I have used the heavy Hitec plastic arms with ball links without failures. However keep in mind that I rarely fly a plane more than a couple dozen flights before moving on to something else.
The trick is the keep the ball link mounted as close to the surface of the arm (the thick one) as possible to keep torsional forces to a minimum.
TF
