RCU Forums - View Single Post - Cen MT2- NT-16 to 18 conversion results
Old 03-21-2005 | 01:16 AM
  #42
rolland
Default RE: Cen MT2- NT-16 to 18 conversion results
If the rod is hitting the block you could grind a little bit of it away with a Dremel to gain clearance. I had no problems with the .18 rod in my engine.
I also wouldn't trust the stock .16 rod with the .18 piston for very long ( there is a reason CEN uses a beefier rod on the .18)
rolland
