RCU Forums - View Single Post - Capiche 140 EX and IC version
Old 03-21-2005 | 05:29 AM
  #2666
Berk's Avatar
Berk
Default RE: Capiche 140
I used the IH hinges in the end on Rudder/Elevator after finding the big aileron Gap using the Kavan hinges!!!, and have now sealed the small gaps at the tail end..just the ailerons to seal, then it's all Done!!
I've Setup the low/high rates as per the Instruction leaflet with -20% expo, which doesnt look like a lot of movement, even high rates. I guess it will be enough as they are large surfaces
I also set extreme rates with - 40% expo, which does look like a lot of movement!!
I have checked nothing is binding, but it's singing like a sub-station. 8411s and 8511s do this, apparently.
Engine now installed!!
4* CP1700s just in front of the CofG will (when cowl added) balance correctly.
Still trying to figure out why the throttle goes to idle when i switch off the TX.. I havent set up a F/S....
Regards,
Steve
